Sculpting with superglue-soaked paper tutorial
AdrienVeidt
Apr 11, 2015
996
I was asked for some explanation of what I meant by 'sculpting with paper' when I described how I made my recently-posted Werewolf's torn pants cuffs. It's basically using a rough, permeable paper as scaffolding to soak with superglue that can be filed to a desired surface texture once filed.
Here, I'm bashing the Indy line's Marion Ravenwood with a RoC Cover Girl to give her some proper hip and knee articulation. I've scrounged up a Discover magazine subscription postcard found generously inserted loosely between the pages. It's similar to a kids kid's construction paper, and that should be just as useful. It's key that your paper can't have a coating on either side that would prevent the superglue permeating into the it.
I've cut a piece off the postcard a tax longer and wider than needed, to account for warping around her abdomen. I bent, folded, warped, and spindles the paper a bit so it'll be easier to conform to her and look like fabric. I've glued one end to CG's back and glued it down as I wrapped it around, ensuring the paper lays down with some natural-looking clothing folds. I want the straight edge at bottom, to become her shirt's bottom hemline.
Once I got the paper in place, I trimmed any excess hanging over the lower hemline (there was a tad bit in back), then laid down another layer of superglue to the paper's exterior. I tried to blackwash it so it'd be better-visible, but I fear my camera flash washed the wash away.
Once the exterior glue dried, I filed at it to get the smoother surface I wanted, and to emphasize the folds I want. This filing will sometimes expose inner paper where the glue didn't seep and it will look 'hairy'. Another glue application easily resolved this.
I use this technique fairly often as it's quick and easy compared to proper putty-sculpting. I've used it to tighten joints, cover screwholes, and fake up clothing; and probably a few other uses I've forgotten. Put it in your arsenal as I'm sure it'll be of use somewhere.
44
How durable is it?
This seems like a nice and easy technique. Another one that can get a similar effect is to paint acrylic in layers over paper and then using water to separate the paper. You're then left with a flexible acrylic sheet. Plus, if you have camo printed on the paper, it will retain the print.
AdrienVeidt
Apr 11, 2015
996
If you're laying it down flat like this piece here, it's basically solid plastic since volume-wise it's more dried superglue than paper. If it's an overhang like the Werewolf's pants cuffs, it's about plasticard tough. It can be torn if enough force is applied the necessary way, but that's only ever happened to me when I wanted to redo it and deliberately tore it off. For the posing play us guys do with our figures, I've never had any problems.
That second method you mention could use some tutorial pics, too. I dunno that I could tear a layer off in one solid piece.
