So, a few weeks ago, I finally took the time to field strip my airbrush and fix whatever was gummed up in it so that I could do some painting in the garage airbrush booth as the weather got nicer. Having accumulated a lot of noggins for various projects, I wanted to try a technique I read about several years ago in regards to painting heads/faces.
The gist of the idea is that you primer the heads in grey, then after it dries, you go back and shoot them with black upwards from under the chin, getting the underside of the eyebrows, nose, mouth, etc. And once again after it dries, you go back and shoot them with white looking down from above the forehead, getting the cheekbones, top of the nose, top of the chin, etc. The effect is a spooky shadow/highlight combo that really accentuates the details in sculpts. And then when you shoot fleshtone over the faces, it'll give the paint more tones in exactly the right places, far more detailed looking than if you just brushed fleshtone all over it... like I normally do... like a caveman.
I haven't gotten to the flesh coat yet, but here are some pics of the black & white effect. You don't realize the dramatic effect it has until it dawns on you that the harsh shadows and highlights are not all from the actual light source. It already makes the sculpts look far better than most 1/12 noggins. Hopefully the effect continues to work as described once I add the skin tone. The trick will be to spray it on thick enough to cover without being so thick as to obscure the underlying tones.
Plus, it's not hard to figure out what customs I've got coming next
